I don't think I've ever used any more than a screwdriver to build a PC.
https://linustechtips.com/topic/1401689-pc-building-toolkit/#findComment-15191700
All you need is a Philips #2 (and possibly Philips #1 or #0) screwdriver.
You don't need any other tool to build a PC.
Maybe some zip ties, and something to snip / trim the zip ties if you want to do a bit of extra cable management.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1401689-pc-building-toolkit/#findComment-15191708
now days its all PH2 heads.
I would add pliers/wire strippers but wire strippers are used in weird situations.
(pliers are useful retrieving fallen screws and some stupid little things)
I have built a entire pc with just a multi tool
Everyone, Creator初音ミク Hatsune Miku Google commercial.
Cameras: Main: Canon 70D - Canon 7D MK2 - Secondary: Panasonic GX85 - Spare: Samsung ST68. - Action cams: GoPro Hero+, GoPro hero 6 black
Dead cameras: Nikion s4000, Canon XTi
Pc's
Towers:
Main Dell optiplex 5050 "Bandog"  - intel i7-7700 - nvidia t400 4GB - 20GB ram - 1TB Samsung 990 Pro heat sink - 256GB Samsung 850 - 5TB HDD
old windows 7 gaming desktop - Intel i5 2400 - lenovo CIH61M V:1.0 - 16GB ram - 1TB HDD
Laptops:
main laptop "Soppo": Lenovo P14s Gen 5 - Intel ultra 5 135H - Nvidia 500 ada - 32GB ram - Samsung 990 pro 1TB
Secondary/radio programming laptop "Klukai": Dell Latitude 5430 - Intel i7 1185G7- 16GB ram - Kioxia BG6 256GB
Tertiary/Networking/radio programming laptop "Persica": Dell latitude 5414 Rugged - intel i5 6300u - 12GB RAM - Samsung 870 EVO 500GB
Any questions? pm me.
#Muricaparrotgang
https://linustechtips.com/topic/1401689-pc-building-toolkit/#findComment-15193037
iFixIt tool kit has everything you need and beyond.
But still, first of all, what are you building, what do you intend to build.
For normal PC, screwdrivers (PH2 or Philips 2 or +2) are pretty much sufficient, you may also need precision screwdriver (PH1 or PH0) for M2 SSD. Also, try to get a magnetic tip screwdriver if possible. I also recommend a hex wrench to screw the motherboard stand-offs but you can screw it using your hand too.
Also, depending on your situation, you might want to get a thermal paste ready (if your CPU cooler doesn't come with thermal paste). You also may want to get a plastic ruler or screwdriver with long tip to pry open some latches (such as PCIe slot latch) because they are very hard to access if GPU was installed into it and for some reason you need to remove say GPU.
For custom water cooling, well, I mean that's another topic. Many do offer tool free assembly, but if you are going to use hard tubing, you might need a heat gun and bender to bend the tube.
Last but not least, anti static mat or anti static wrist strap, or access to any metal connected to ground to discharge ESD build up. If you live in humid area, you can skip this step, but if you live in dry area, you might need it to protect your sensitive electronics component.
I have ASD (Autism Spectrum Disorder). More info: https://en.wikipedia.org/wiki/Autism_spectrum
I apologies if my comments or post offends you in any way, or if my rage got a little too far. I'll try my best to make my post as non-offensive as much as possible.
https://linustechtips.com/topic/1401689-pc-building-toolkit/#findComment-15193171
On 1/6/2022 at 11:07 AM, Alex-Bubbler-Leo said:
Do you know if there is any toolkit designed for pc building, having anything I may need to build a pc?
What Tools Are Needed to Build a PC?
“Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.” - Albert Einstein
https://linustechtips.com/topic/1401689-pc-building-toolkit/#findComment-15203225
When I was 8. I stole a screwdriver from my dad to take apart a computer for the first time. It proved to be so useful and the only tool needed, that to this day, that same screw driver is the only tool I generally need or use when doing PC work.
Quote
"Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so." - Douglas Adams
System: R9-5950x, ASUS X570-Pro, Nvidia Geforce RTX 2070s. 32GB DDR4 @ 3200mhz.
https://linustechtips.com/topic/1401689-pc-building-toolkit/#findComment-15203494
Yeah surprised no one else mentioned this. Side cutters are a must.
Depending on the quality of the case, a good set of blunt nose pliers may also be required. A lot of low end cases have (or at least used to) have the PCI slot covers still attached to the case and you had to bend/break them off individually.
https://linustechtips.com/topic/1401689-pc-building-toolkit/#findComment-15205432
Yeah, forget about that, but usually, you can use bare hand to bend it back and forth a few times and it'll eventually snaps. Usually, I just buy a few of PCI covers and screw them in after removing the PCI covers.
On a side note, if the case has a cover for 5.25 inch bay drive... Damn, the Cooler Master E500L/E501L, that metal cover is really hard to break it off.
https://linustechtips.com/topic/1401689-pc-building-toolkit/#findComment-15216866
