Cooler problem for i7 6700k
Solved by MidnightMyth,
16 minutes ago, Jzan said:I always recommend a Noctua cooler. Check out the link below and scroll all the way to the bottom to see 4 options that should all be great but find the one to at first your needs best. If you aren’t interested in a Noctua cooler let me know and I can try and find some other options.
Ive looked into those also but I saw mixed opinions some say it won't be enough for this and some say it will... Usually my pc runs more then 10h with sessions up to 8h sometimes will it hold?
