I need help picking out my Motherboard, cpu and memory.
$250CAD is a tight budget for CPU, RAM, and motherboard. For current gen stuff, the i3 is pretty much the only option, as Ryzen 3 is either out of stock or held hostage by scalpers at the moment. Considering that the graphics card is a GTX 1060 3GB, the i3 should be perfectly sufficient. It's basically as if you paired it with an i7 6700 - 5 years ago no one would have said that CPU was too weak for the card.
I'd aim for a B560 motherboard if you can afford it, as that will allow you to run RAM at its rated XMP speed, which is important to get the full performance out of a 10100F. You can pair it with a 2x8GB kit of DDR4-3200 or DDR4-3600 RAM. That would be the ideal combo, but I don't know how easy that will be to make work within the budget.
