optiplex case fan
Go to solution Solved by thrasher_565,
i think you can fit a 92mm if its off center a bit because of the square grill.. no mods needed
https://linustechtips.com/topic/1399619-optiplex-case-fan/#findComment-15179288
On 12/29/2021 at 4:49 PM, Mattias Edeslatt said:
Well, with the answer you got and with a quick search with your favorite search engine reveals that it is a 80 mm fan. Wasn't so hard to find out...
But if you want a 100% correct answer open your case and measure yourself.
mesures to 90 mm
https://linustechtips.com/topic/1399619-optiplex-case-fan/#findComment-15180798
  • 3 months later...
6 minutes ago, Meatball the man said:
it worked with the rubber things
nice
https://linustechtips.com/topic/1399619-optiplex-case-fan/#findComment-15358873
