Air mini fan configuration
Solved by thrasher_565,
9 hours ago, ZonalThrone said:Hi, I have a 240 aio and I’m switching cases to the Lian li o11 air mini. It comes with one 120 in the back and two 140 in the front. I’m thinking of moving the ones in the front somewhere else to put my aio in the front. Is this a good idea? And should I put those front fans on the bottom, top, or side? Thanks!
front intake for aio will be cooler gpu a little hotter, aio on top a little hotter but gpu a little cooler.
i would put the fans on the bottom
