Need help with first build
Go to solution Solved by RONOTHAN##,
https://se.pcpartpicker.com/list/TtPFW3
this is what I'd build, but I'd try to find a better GPU. the market is pretty bad right not, and this would hold you over until you can afford a good GPU in a year or so.
Budget (including currency): 1300 $ USD
Country: Sweden
Games, programs or workloads that it will be used for: F1 2021, COD Vanguard, Minecraft, Streaming, Apex and Forza Horizon 5
Other detail Hi. I have about 1300 dollars to work with and I want to get the best performance I can get for my money. I also live in Sweden. My goal here is to be able to play these games with as little lag as possible. I also want to start streaming. Right now I have a computer that struggles with the easiest games like CSGO. In the furture I’m aming to have 3 screens, all 1080p and 1 144hz . Do you guys have any recommendations or build I can use.
https://linustechtips.com/topic/1398008-need-help-with-first-build/
https://se.pcpartpicker.com/list/XVMVqp
CPU: Intel Core i5-10400F 2.9 GHz 6-Core Processor  (kr1449.00 @ Amazon Sweden)
CPU Cooler: be quiet! Pure Rock 2 Black CPU Cooler  (kr401.00 @ Amazon Sweden)
Motherboard: MSI MAG B460M MORTAR Micro ATX LGA1200 Motherboard  (kr1344.00 @ Proshop)
Memory: G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (kr693.00 @ Komplett)
Storage: Western Digital WD_BLACK SN750 500 GB M.2-2280 NVME Solid State Drive  (kr665.00 @ Amazon Sweden)
Storage: Crucial MX500 1 TB 2.5" Solid State Drive  (kr968.84 @ Amazon Sweden)
Video Card: Asus GeForce GTX 1650 G5 4 GB DUAL OC Video Card  (kr2764.00 @ Dustin Home)
Case: Lian Li LANCOOL 205M MicroATX Mid Tower Case  (kr649.00 @ Proshop)
Power Supply: SeaSonic FOCUS GX 650 W 80+ Gold Certified Fully Modular ATX Power Supply  (kr649.00 @ Amazon Sweden)
Case Fan: Corsair iCUE SP120 RGB ELITE 47.7 CFM 120 mm Fans 3-Pack  (kr636.70 @ Amazon Sweden)
kr10219.54
Not the best of circumstances of course, but I would easily recommend at least a GTX 1650 over any APU right now. You'll get way better fps, cooling, and performance.
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
kr10219.54
Thank you so so much.
Thank you will look at this later
https://se.pcpartpicker.com/list/KyvjYg
Threw away any sort of uneccesary crap like rgbs, cheaped out on literally everything, and now you might be able to get a 3060 if you are lucky or even a 3060ti if you are willing to go abit overbudget
At this pricepoint if you wanna build something with a dedicated gpu rgbs have to go or youll be stuck with a pitifull 1650 or 1660, if you want rgbs then youll have to go overbudget
I'd recommend you to wait for the upcoming i5 12400 & 12400f CPUs. Also, they will launch with the cheaper 'B660' chipset Motherboards.
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
