Cases and coolers:
I am sorry to introduce myself with a rant.. But.... I am going to do just that,
Thermaltake UX200 ARGB CPU AIR COOLER - 120MM
This, on the face of it seems to be a very nice cooler, epecially if you have a glass-sided or fronted case. Unfortunately it does not fit. In any of my four current builds. Including one made by .... TT Thermaltake.  Do your designers not speak to one another? Do you not use MS Teams or Zoom?
My (very nice) case is a TT Divider 300TG. (This is not an iTX or mATX case, is is a very large mid-tower) ...
I quote from my after- purchase research..
"Max height of cooler 145mm"  This means than NO decent air-cooler will fit, even though the case is on the large side. Plenty of room for cables behind the back-plane, but no room in front for..... A CPU cooler! So my perfectly adequate Arctic Freezer 34 is in the bin. As is my Raijintech Thermis. And ALL decent air -coolers, Corsair, Cooler-Master, Noctua, etc. even the one made by ThermalTake themselves.
Dimensions of the UX3200:
    127 x 76 x 153.5 mm ( L x W x H)
And from the spec-sheet of my case on TT's website...
"Max height 145mm"
(It is a fairly large case).
This is, IMHO stupidity. One of the most important dims for a case is what fits in it. This is not a small case. And it is not "budget" or "bottom end"  And this is the same mfr. !
I can't return the case, nor can I return the coolers. And now, I can't keep my Xmas promises. FMAL!
https://linustechtips.com/topic/1397054-thermaltake/
As you noted looking at the specifications of your products before buying would have kept you from this problem.
That is a case that was designed with AIOs and water cooling in mind. Good luck finding a 360mm or small AIO that won't fit in that case.
There are many really good air coolers that will fit from most of those brands.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1397054-thermaltake/#findComment-15162135
I have to disagree! @IkeaGnome This is a big(ish)  mid-tower and is not at the budget end of the market. To have to drill-down in to the small-print, only to find that their own products do not fit is, to say the least, slightly annoying.
And the retailers or manufacturers might have stated that:
"No mainstream coolers will fit in this large case."
https://linustechtips.com/topic/1397054-thermaltake/#findComment-15162195
The specs are hardly fine print.
Halfway down the page is also not fine print. It's in their marketing materials on the main page for that case. Every picture with an assembled system uses an AIO.
That's like saying "How dare Ford make rims that don't fit a F550!". "How dare 'xx phone manufacturer' change cables. My old cables don't work with my new phone."
There's different products for different markets. They are very open about that case only fitting a 145 mm cooler.
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1397054-thermaltake/#findComment-15162206
Thank you for replying to my rant, But surely, it is quite mad to sell products which do not fit? I thought that buying a "nice"  and quite large case, I could expect " things to fit" at least, with a bit of knowledge, or jiggling.?
But no!
Surely case-sellers should advertise "This is a fat case and will happily contain any and all maiinstream CPU coolers, including  those made by Arctic, Corsair, Noctua, Raijinstech, (etc).
Or "This is a huge metal box, of very good quality, but no decent kit will fit in it."
https://linustechtips.com/topic/1397054-thermaltake/#findComment-15162228
But no!
So by your logic, because Thermaltake makes 360mm liquid coolers, they should never make any mATX or ITX cases because 360mm coolers won't fit in them? They're required to have all of their products be compatible with each other, even ones designed for totally different purposes?
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1397054-thermaltake/#findComment-15162257
But no!
What about Intel using the same socket for ages, but has CPUs that won't work on that same socket that use the same socket.
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1397054-thermaltake/#findComment-15162280
Not every cooler is going to fit every case, that's just how it is regardless of who made either.
It's up to the buyer to check and see by the specs if a cooler will or will not fit.
I did see where you said you checked but this expectation of "If they made it, the cooler should fit" isn't correct. If you really didn't bother to check it out and assumed it would before buying that's on you.
"If you ever need anything please don't hesitate to ask someone else first"..... Nirvana
"Whadda ya mean I ain't kind? Just not your kind"..... Megadeth
Speaking of things being "All Inclusive", Hell itself is too.
https://linustechtips.com/topic/1397054-thermaltake/#findComment-15162290
What on earth am I reading?
Why would you think that just because 2 products are made by the same company, they'd work together? That's not at all how products work.
You actually don't have a very large case. It's a mid tower, it's average sized. If it was a large case, you'd have room for a larger cooler.
After purchase research? You do know you're supposed to research what you buy before you purchase it right? Especially for something you can't return.
So, basically, you're upset that you bought some things that don't work together, because you were too lazy to go look up the compatibility part of the web page. You just looked at it and said "hmm, same manufacturer, must work." Which is the completely wrong way to do anything.
Pro life tip: Frank Products makes bleach. They also make ammonia. These two things cannot be used together.
It is, though. $100 is far closer to the budget end then the high end.
So you think you shouldn't have to look at what's compatible before you purchase something? That's ridiculous.
Or
"This is a case made for AIO's and water-cooling, and no mainstream air-cooler will fit, even our own".
It works with air coolers. Why would you say it doesn't? Not sure you know how marketing works.
But no!
Not at all. They make products for several different uses. The case isn't even that large, it's a mid tower.
The specifications are there for your reading. They tell you what will fit, and what won't. Why would you assume that you can "jiggle" something into fitting?
There are many, many decent kits that will fit in this. Just none that you seem to want (liquid cooling). That's a you problem, not a product problem.
42 minutes ago, Wakou said:
Are there any decent cases that will take a "tower-cooler"? (150/160mm) Or am I stupid?
I can't afford to buy another case. I could hardly afford this one.
I'd suggest you do far more research with your next purchase if you're having trouble affording it.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1397054-thermaltake/#findComment-15162300
Thank you all! But surely there should be a warning.. "This case is quite big, but cannot accept ANY decent cooler, even those that we make ourselves..This case is ONLY for water-cooling?
I have Arctic Freezer, and Railjintech ... And have tirelessly researched Corsair, Noctua etc.
This is a quite big case... I could buy a 92mm cooler.. But FMAL!
https://linustechtips.com/topic/1397054-thermaltake/#findComment-15162306
No.
https://linustechtips.com/topic/1397054-thermaltake/#findComment-15162311
Imagine average Joe, buying a toy for his child for Christmas.. "But you did not check the precise milimetres! Its all your fault!"
"But I looked at dba and cfm and W/cm3 and fittings of AM4 and Intel and I FORGOT to check that manufacturers like to flog stuff" ...
Show me a case in real life that takes any of those coolers.
Any other industry, it woiuld be simply unacceptable. Or illegal.
https://linustechtips.com/topic/1397054-thermaltake/#findComment-15162326
Indeed, it is Joe's fault. Joe is an adult, and so are you. It's not the child doing the purchasing. If you're buying a technology product, it's your duty to do your research. If Joe doesn't want to bother, he can buy Joe Jr. a console.
No amount of laws can protect foolish people from themselves.
It is not possible for Thermaltake to list every cooler ever made and say whether or not each one is compatible. They provided the maximum cooler height, very clearly. All reputable CPU cooler manufacturers provide the height of their products. You had all of the information you needed to avoid running into this problem. You overlooked it. Now I'm sure that makes you feel silly, and I sympathize with your plight. What I can't understand is why you feel the need to make yourself look sillier by doubling and tripling down like this publicly.
https://linustechtips.com/topic/1397054-thermaltake/#findComment-15162343
Of course there are cases that can accomodate an ordinary cooler. But surely cases which do not should say so?. I used to run my PC literally in a cardboard box under my desk. For years!. It was fine. But surely if a company is selling "up-market"  cases  they sould be up-front about the possibilty that a cooler with a 120mm fan won't fit?
https://linustechtips.com/topic/1397054-thermaltake/#findComment-15162345
It happens all the time. It's called not checking to see if the toy comes with batteries or not. You know what it's definitely not? Illegal.
You're not getting out of this. You're in the wrong, and you just have to suck it up and accept that.
If you can't handle building a PC, you should be buying a prebuilt.
https://linustechtips.com/topic/1397054-thermaltake/#findComment-15162346
They did say so. Right here. Do you need them to make the text blink like an old GeoCities site, maybe?
https://linustechtips.com/topic/1397054-thermaltake/#findComment-15162348
Wakou emerges from his hiding-place..
But! But! I am an IDIOT!...
Surely, sellers of coolers should clearly state:
"ATTENTION IDIOTS!
This cooler runs silently and has the capacity to cool 1Kg of molten aluminium to ambient temps within 30s. It could blow a 44 tonne truck off of a bridge from a distance of 1 KM.
But it will not fit in 90% of PC cases, so, please don't buy it!"
OTOH, The Arctic Freezer 34 eSports (cough cough, purchased off of Facebook Marketplace from a neighbour for £6.00) has a very good PWM fan included. And the Raijintech also has a nice fan, I'm sure that I will find a use for them...And the PC that I am building for my elderly father is not going to be used for 4K shooting games. And I have a "stock" AMD cooler, which will I am sure, be quite adequate (he is slightly deaf!.).
(Wakou eyes up his recently purchased ASUS GTX 1070, with its ever-so-slightly annoying little blower fan, and wonders "What if I dremel the F out of that shroud and zip-tie some decent fans on to it?)
You can all expect some stupid questions in other areas of this forum, in the near future!
Thanks again! xxx
https://linustechtips.com/topic/1397054-thermaltake/#findComment-15162673
