Corsair 7000D AIRFLOW ATX Full Tower Case has a front panel USB 3.2 Gen 1 Type A port, but the Gigabyte Z690 GAMING X DDR4 ATX LGA1700 Motherboard does not have sufficient USB 3.2 Gen 1 headers. The case USB 3.2 Gen 1 Type A port will not be usable. What does that mean?? Please i need help.
https://linustechtips.com/topic/1396387-please-help-me/
It means you won't be able to use the Type C port on the case.
Dunno why pcpp would say type A, thats just a goof.
https://linustechtips.com/topic/1396387-please-help-me/#findComment-15157886
Just now, Serju Iurcu said:
Is that a big problem?
Only if you planned on using the type C port on the case
https://linustechtips.com/topic/1396387-please-help-me/#findComment-15157892
47 minutes ago, Serju Iurcu said:
Ok but there is no other problems right? Since its the first pc that i will build i want to make sure everything is fine. https://ca.pcpartpicker.com/list/W68pdD Here if you want to see the pc parts
You should not be paying that much for windows. Correct if if I'm wrong but doesn't 12th (alder lake) intel benefit from be using windows 11, right? I can tell you a website for an OEM or retail windows 11 key (where I got mine for $3) genuine of course. I've used the same windows 10 key from there on 5 different systems. No issue.
First watercooled System
Build Name: White Knight
OS: Windows 11 Pro 64-bit
Monitor: Alienware AW3423DWF 1800R Curved Ultrawide 3440x1440 QD-OLED 157hz 10 bit 0.1ms
Chassis: Lian Li 011 Dynamic EVO w/ 2x120mm Corsair QL RGB Fans on the bottom 1x120mm on back exhaust
Top Rad & Fans:  Corsair 54mm 360mm w/ 3x120mm Corsair ML Pro RGB Fans
Side Rad & Fans: Corsair 30mm 360mm w/ 3x120mm Corsair QL RGB Fans
Motherboard: Asrock X670E Steel Legend
CPU: AMD Ryzen 7 7800X3D w/ Corsair XC7 RGB Pro w/ Kyrosheet
Memory/RAM: Corsair Dominator RGB DDR5 2x16GB 32GB 6000Mhz
GPU: Asus GeForce RTX 4080 TUF w/ EK-Quantum Vector2 Nickel/Plexi & Backplate
Pump/Reservoir: Corsair XD5 RGB
Coolant: Corsair Clear
PSU: Lian Li Edge 1000W
Boot/OS SSD: Samsung 970 EVO Plus 500GB NVMe
WZ/2042 SSD: Samsung 850 EVO 250GB
Game SSD: Samsung 980 Pro 1TB
Performance/Editing HDD: Western Digital Black 1TB
Storage HDD: Western Digital Blue 1TB
Mouse: Razer Lancehead Tournament Edition/Razer Mamba
Mouse Mat: Corsair MM700 RGB
Keyboard: Razer Ornata Chroma
Microphone: Beacn Mic
Headset: Razer Blackshark v2 Pro
Eyewear/Glasses: Gunnar Optiks Razer FPS/Gamer Advantage Liquid
Camera: Razer Kiyo Pro/OBSBOT Meet SE
https://linustechtips.com/topic/1396387-please-help-me/#findComment-15157937
Yeah i would like to know because that windows is expensive.
https://linustechtips.com/topic/1396387-please-help-me/#findComment-15159138
Pcpp is not always 100% accurate. If you check the websites for your case and mobo you will see that they both have USB type C headers.
In fact the generations don't matter on the case since it's just an extension cable going to a plug. The Mobo has USB 3.2 gen 2 for the front panel connector.
https://linustechtips.com/topic/1396387-please-help-me/#findComment-15159147
Right never paid full price for windows ever since I've been gaming a working on PC since 2011 Christmas eve. 🙂
I can post links here I believe.
Website is: https://www.hrkgame.com/en/games/product/windows-11-professional-retail
That's the one I bought and am using currently. So for you're 12th gen intel recommend 11 anyways.
https://linustechtips.com/topic/1396387-please-help-me/#findComment-15159580
I belive that windows 10 pro is better than windows 11 pro for gaming tho
https://linustechtips.com/topic/1396387-please-help-me/#findComment-15159582
Not on your 12th gen intel. You have two different cores now P(performance) and E(efficiency) cores. Windows 11 works fine and I see no difference even though I'm on a ryzen which doesn't benefit but doesn't hurt it either with the latest update as far as I can tell.
Look up a video about 12th gen intel or your specif CPU they'll explain it better than I can.
https://linustechtips.com/topic/1396387-please-help-me/#findComment-15159586
