Budget (including currency): Roughly $1700 CAD
Country: Canada
Games, programs or workloads that it will be used for: Apex, League, Tekken, Valorant, general games, schoolwork, and 3D modelling.
Recently I've been able to purchase the RTX 3060 for retail price at BestBuy. I've spent the past couple of days doing research on which parts to buy. This is my first pc build and I just want to make sure that everything is good, as I'm not sure which parts are good or bad. I think that my list is relatively balanced so far but I would like any advice for anything that I might want to switch out. I'm fine with going slightly above the budget if it means that I will be getting better performance for a good price.
I have already purchased my mouse, keyboard, and monitor.
Here's the list: https://ca.pcpartpicker.com/list/4mtYp2
https://linustechtips.com/topic/1395481-first-pc-build/
Overall this is a great build. You can tell you put the last few days into researching what to buy. Most of what I'd change would just be personal preference.
That said, I'd probably look into going for Alder Lake instead. The 12600k is much faster than the 5600X for the same price. The motherboards, however, are a bit more expensive, and you will need to get a good cooler to be able to use it. That said, you can still squeeze it into your budget without too much issue.
https://ca.pcpartpicker.com/list/RLrQj2
The biggest disadvantages of Alder Lake are its power draw under load and that it's a bit more bleeding edge, so don't be surprised if you run into some occasional issues. That said, they'll probably be ironed out in a few months, and it performs enough better that they it's well worth it.
https://linustechtips.com/topic/1395481-first-pc-build/#findComment-15152030
Thanks for the advice! I'll consider going to an intel build. It all really depends on what will be hopefully on sale around Christmas time.
https://linustechtips.com/topic/1395481-first-pc-build/#findComment-15152035
First of all, I really feel jealous that you got a 3060 for a retail price. Second, I do not recomend using a cooler given from the CPU packet since my friend is experiencing 90 degrees with a 3600. I would recommend getting a Noctua cooler like this(https://www.amazon.com/Noctua-redux-1700-high-Performance-Award-Winning-Affordable/dp/B07CG2PGY6/ref=sr_1_3?keywords=noctua&qid=1639365444&sr=8-3) or a liquid cooler like NZXT Kraken. Third, the SN550 might not be the best choice since it kind of lost its value after they changed it parts and the speed went down. I would recommend Samsung 980 Evo 1TB even though it is expensive since we can trust its performance. Lastly, I have no idea what monitor u purchased but I hope its a fhd 144 monitor.
I might be wrong so tell me if so.
https://linustechtips.com/topic/1395481-first-pc-build/#findComment-15152160
I got lucky with the card. I went to BestBuy hours after their in-store restock event and found one of the last cards still available for purchase. As for the stock cooler, I'm not quite sure about the thermals I'll be getting with it. I've heard many people say that it's fine but I'll look into that.
I was not aware of the changes to the SN550 but I'll probably have to keep that to stay closer to my budget. But if the Samsung SSDs do drop down in price I will get those instead.
Thanks for the extra info! And yes I do have a FHD 144hz monitor.
https://linustechtips.com/topic/1395481-first-pc-build/#findComment-15152216
There you go....
PCPartPicker Part List
CPU: Intel Core i5-12600K 3.7 GHz 10-Core Processor  ($359.99 @ Memory Express)
CPU Cooler: Noctua NH-U12S 55 CFM CPU Cooler  ($79.95 @ Amazon Canada)
Motherboard: Asus PRIME Z690-P D4 ATX LGA1700 Motherboard  ($259.00 @ Canada Computers)
Memory: Patriot Viper Steel 16 GB (2 x 8 GB) DDR4-3733 CL17 Memory  ($89.99 @ Amazon Canada)
Storage: Silicon Power P34A80 1 TB M.2-2280 NVME Solid State Drive  ($124.99 @ Amazon Canada)
Video Card: Zotac GeForce RTX 3060 12 GB GAMING Twin Edge Video Card  (Purchased For $649.99)
Case: Cooler Master MasterBox NR600 (w/o ODD) ATX Mid Tower Case  ($81.83 @ Vuugo)
Power Supply: BitFenix Whisper M 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($79.88 @ Canada Computers)
Total: $1725.62
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1395481-first-pc-build/#findComment-15159990
I'd look at NVME drive with dram. Here are some options:
Storage: ADATA XPG GAMMIX S11 Pro 1 TB M.2-2280 NVME Solid State Drive  ($119.99 @ Amazon Canada)
Storage: Western Digital WD_BLACK SN750 1 TB M.2-2280 NVME Solid State Drive  ($149.99 @ Canada Computers)
Storage: Team MP34 1 TB M.2-2280 NVME Solid State Drive  ($144.99 @ Newegg Canada)
Storage: Mushkin Pilot-E 1 TB M.2-2280 NVME Solid State Drive  ($128.99 @ Amazon Canada)
Storage: PNY CS2130 1 TB M.2-2280 NVME Solid State Drive  ($163.49 @ Amazon Canada)
Storage: ADATA XPG GAMMIX S7 1 TB M.2-2280 NVME Solid State Drive  ($194.53 @ Amazon Canada)
There is also a gen 4 ssd that's on a really good deal to consider because it's not too much more than gen 3:
https://linustechtips.com/topic/1395481-first-pc-build/#findComment-15160614
