I just installed PopOS and i opened the PopShop and downloaded a gmail client.
Then i was looking at another interesting application when my screen went....well you can see in the picture.
it was stuck there with more gltchiness until i had enough and held down the power button to force shut down.
I pressed the power to turn it on and now it wont even post and when i hold the power button to Force shut down it turns itself back on somehow????
Its my first time on Linux so help is much appreciated.
PC: Ryzen 5 2600, 16GB 3200mhz RAM (8GBx2), Gigabyte B550M DS3H, GTX 1050 2GB, 650W Semi-Modular PSU80+ Gold
Phone: Poco F3 8GB + 256GB
Audio: Samson SR850s
Sound Card: SoundBlaster Play 4 USB sound card
IEM: planning to get the KBEAR KS2s
Please be patient with me, I'm fatally dumb and its honestly a miracle I've made it this far
https://linustechtips.com/topic/1394665-help-popos-crashed/
That sounds like a hardware issue, not a software one.
How old is this system?
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1394665-help-popos-crashed/#findComment-15146228
its a Dell Optiplex 755 with a Intel Core 2 Duo. it also has a Windows XP badge. release date was around 2008
https://linustechtips.com/topic/1394665-help-popos-crashed/#findComment-15146249
Eliminate the smaller things first- try a different video cable, swap ram slots, etc
https://linustechtips.com/topic/1394665-help-popos-crashed/#findComment-15146258
Can you get into the BIOS of the PC?
https://linustechtips.com/topic/1394665-help-popos-crashed/#findComment-15146299
Nope. When I turn it on there's nothing being displayed. Just blank
https://linustechtips.com/topic/1394665-help-popos-crashed/#findComment-15147357
Will do
https://linustechtips.com/topic/1394665-help-popos-crashed/#findComment-15147358
Try remove the ram, clean the RAM contact with rubber eraser or a plain paper. Make sure the RAM slot is dust free before you plug it back in.
https://linustechtips.com/topic/1394665-help-popos-crashed/#findComment-15147417
BTW I should mention its 2GB of DDR2, would that be an issue?
https://linustechtips.com/topic/1394665-help-popos-crashed/#findComment-15147464
Shouldn't be an issue if the RAM itself is not faulty.
https://linustechtips.com/topic/1394665-help-popos-crashed/#findComment-15147511
