Stabilizers for TM680?
char3327
Hey y'all,
    So I am planning on getting a TM680 for my first keyboard build and wanted to get new stabilizers. I can't seem to find is the board uses plate-mounted or snap-in stabs? If anyone knows or could find out that would be appreciated. Also if anyone has suggestions for good, budget stabs that would also help. Thank you!!
On 12/7/2021 at 2:33 AM, char3327 said:
Hey y'all,
TM680 uses plate mounted stabilisers from what I can see. Could look at durock plate mount or everglide panda plate mount, iirc you can clip the everglades and durocks are pre-clipped
finally escaped fm2+
