Best fan curve for my PC?
MrManWho
I was just wondering what the best fan curve would be for my PC, I don't know what specs I should post, just let me know if anyone is willing to help.
Your motherboard, CPU, GPU, and Case. Also will need to know what type of fans you have, 3 pin, 4 pin, make/model and what you're looking to accomplish with said curve.
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
Generally I would say that the best fan curve for all PC's, are the fan curve that gives you the most airflow, without sounding like a jet engine.
That said though, this is how I tune my fan curves:
At idle, I aim for the lowest possible fan RPM, while still holding proper idle temps. I do this because when my PC isn't doing anything special, fx gaming, and doesn't need huge amount of airflow / cooling, I want to minimize the dust intake.
Then at load, I tune the fan curve to the highest RPM, while still being quiet. This is also because I'm using speakers while gaming.
Sure, if you're using a headset, you could just crank the fan curve to 100%, because you can't hear the fans anyway, but I still wouldn't recommend this. Tune the fan curve to the lowest RPM possible, while still holding acceptable temps, so you minimize dust intake.
PC Setup:
HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel
Intel Core i7-10700K + Corsair Hydro Series H100x
G.SKILL TridentZ RGB 32GB (F4-3600C16Q-32GTZR)
ASUS ROG STRIX RTX 3080Ti OC LC
ASUS ROG STRIX Z490-G GAMING (Wi-Fi)
Samsung EVO Plus 1TB
Crucial MX500 2TB
Crucial MX300 1TB
Corsair HX1200i
Peripherals:
Samsung Odyssey Neo G9 G95NC 57"
Samsung Odyssey Neo G7 32"
ASUS ROG Harpe Ace Aim Lab Edition Wireless
ASUS ROG Claymore II Wireless
ASUS ROG Sheath BLK LTD'
Corsair SP2500
Beyerdynamic DT 770 PRO X (Limited Editon) & Beyerdynamic TYGR 300R + FiiO K7 DAC/AMP
RØDE VideoMic II + Elgato WAVE Mic Arm
Racing SIM Setup:
Sim-Lab GT1 EVO Sim Racing Cockpit + Sim-Lab GT1 EVO Single Screen holder
Svive Racing D1 Seat
Samsung Odyssey G9 49"
Simagic Alpha Mini
Simagic GT4 (Dual Clutch)
CSL Elite Pedals V2
Logitech K400 Plus
And also the kind of cooling on your CPU (and GPU if it is aftermarket one) - air, AIO or custom loop, what model(s) or how many rads etc.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
For me, it’s mainly about maintaining a desired noise level (without sudden jumps in noise) whilst maintaining healthy temps in both idle & heavy use cases.
I keep a flat line PWM that spans just beyond typical idle temps (including sudden jumps in temp when Windows does its own random (temporary) background tasks.
For my case/fan enclosure, CPU & GPU sit around ~33-36° idle, with the CPU jumping to 50° when Windows does random background tasks, so I have my flat line PWM set up to 60° to cover that range of temp movement.
My most intense tasks are games, so the CPU doesn’t jump too high in temp compared to the GPU. Here are my curves for my two sets of fans.
CPU focussed case (& tower) fans…Steeper fan curve to jump on CPU temps rising above 60°…
GPU focused case fans…More gradual fan curve as the GPU has its own fans that are very good at keeping temps down…
NOTE: My RPMs are what works for my particular case fan performance within my specific case. Yours will differ. This is why there's no one best solution - everyone's setup is different, so it's about trialling different PWMs & maybe fan types/quantity & placement within your case that gets you toward your ideal noise/performance goals.
The more familiar you are with your system, the better.
Good luck, bud.
