Back in the mists of time, you used to be able to calculate what graphics card you would need for any given resolution... (vertical resolution x horizontal resolution x 3 colours) / 8 = amount of VRAM req'd.
Now; given that graphical capability has gone relatively stratospheric, this is a pointless formula.
How would you calculate what would be the realistic minimum graphical capability required to happily run 4K @ 144hz...?
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
https://linustechtips.com/topic/1390568-historical-equivalent-reference/
I mean even back then the formula was at best a good guess as to what you'd need. Today to just display it any card with the dp port or hdmi 2.1 can do it basically. To run your content well that entirely depends on what you are doing as even a rtx 3090 isn't a 4k 120fps high setting card in all games.
So; high(est) res., high refresh really IS God level graphics then...?
OK; I had it in my head that it was more 'mainstream' than I thought... not to worry.
WHY NOT...?!
It will always not be mainstream. Since the moment something becomes mainstream something else higher end has already replaced it :p.
But really just look at reviews and stuff 4k 120hz stuff is not doable in new demanding games even on the highest end cards without dropping some settings. Yes there are outliers like doom but those are few and far between.
Where does the divide come from? What units of VRAM does that give? If the division is supposed to be multiplication then the formula itself makes sense, but I don't see the link to VRAM.
For 24 bit colour it would be
(vertical * horizontal) [pixels] * 3 [colours / pixel] * 8 [bits/colour] = bits VRAM required to store one frame
If you use transparency as the fourth "colour" change the 3 to 4. In either case you'll see that the memory footprint of a frame isn't that big. Even at 3840x2160 a single frame is only 33 MB. There will of course be a ton more stuff stored in memory like all kinds of textures.
You can use this calculator, for example, to calculate the required bandwidth:
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
I think the division by 8 is converting from bits to bytes, and the color depth (8 bpc) was just left out. But if you assume 8 bpc color depth then it just cancels out with the conversion to bytes anyway, so when simplified it would just be H × V × 3 = frame size in bytes.
From waaaay back in the day, when VRAM was measured in MB, rather than GB as it is today.
Rethinking it, the equation was H x V x 3 / (1024 x 1024); so 1024 x 768 equated to a 2.25 MB card being needed (4MB being the option to choose).
WHY NOT...?!
Right, dividing by those factors makes more sense. Well that formula is universal and won't change. Nowadays it's hard to simply estimate, so you should just look at benchmarks regarding VRAM usage (and be careful about the difference between actual and allocated usage).
