Looking for UW 1440p 144Hz monitor
Solved by Stahlmann,
8 minutes ago, PopsicleHustler said:What about Gigabyte M34WQ? Its the same as G34WQ, but IPS. I can get it for around 550 euros. Reviews are pretty good on it
Link Gigabyte M34WQ, 86,36 cm (34 Zoll), UWQH… | CASEKING.de
I personally don't know much about it. But you can read through this review and make your own opinion on it: Gigabyte M34WQ Review - RTINGS.com
While glimpsing over the review my conclusion is basically: It's a decent mid-range option. A tad slower than the LG offerings and a bit smaller for the color gamut, but still good performance overall.
