How to make a one click shortcut?
Enderg312
Is there a way I can use python to create a one click shortcut button on the desktop rather than using the taskbar?
The desktop is a special version of Windows Explorer. You can switch the Explorer to open items with a single click. You can't change the click behavior of individual shortcuts it displays. To do what you want you'd have to write a program that is already running and displays an item as if it was a shortcut and reacts to clicks.
Put a shortcut to your python script on your desktop and change your preference to open link to single click instead of double click. I do it often for our multitude windows tablet.
If your question is to change this behavior for any user than this is wrong. It's is called a user preference and it is why it should respect the choice of the owner of the device.
