MSI Monitor not showing as HDR ready
Solved by Stahlmann,
On 11/21/2021 at 3:51 AM, irishbeast said:There's no mention of hdr on the ad but when you Google hdr and the model numbers a number of sites say it does.
If not I'll be returning it!
This monitor simply does not support HDR. That's it. If you're specifically searching for HDR monitors you're about £1000 short.
The best HDR monitors in this price range can do is accepting the signal, not really correctly displaying it.
