shockers 3090 high memory temps
orze
my 3090 got some high temps on teh memory around 102c. when i work its the worst.
i saw allot of videos where swithching the pads on them to lower the temps ALLOT.
but i dont know what kind of thermal pads are good to use.. or what thickness i should use. i remeber somthing about 1.5 from jay2cents but id love ur guys view and where to get them
cpu: 5950x
mobo: asus tuf pro x570
gpu: 3090 FE
ram: 32gb G.SKILL Trident Z 3200 c14
psu: Antec HCP1300w Platinum (overkill i know...got it for a good price)
thats all needed right?...i didnt study for this exam....
@Moonzy will be able to assist as they have swapped thermal pads and will be able to give you first hand information.
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
This issue is present on many 3090s and 3080s, I think LTT made a video on that.
My 3090 SuprimX has memory temperature below 75 degrees always, out of box. Usually the expensive ones has good memory cooling like SuprimX, GamingX Trio, Asus ROG Strix and FE cards
Opening up a card voids warranty, hence I sold my Zotac Trinity and Gigabyte Gaming OC and gotten SuprimXs
Best,
Mu
Yup my 3080 is regularly around 100-108. At about 105 it'll blast the fans at full power (but with almost no effect on RAM temps).
Still if it fails it's under warranty, replacing pads would void that so it stays as it is.
F@H
GPD Win 2
listen...i dont care about any of this mambo jambo xD i just want better cooling for it.
its FE and i got it from a place i work with allot so i can get that warrenty anyways.
i asked him if he can fix it for me there but he said he honsrly dosent know how
dont whorry about warrenty and stuff with me. its a work card and its how i pay my bills i want it lasting.
cpu: 5950x
gpu: 3090 FE
By about 10-20c on both of the G6x cards that I swapped, which is the gigabyte gaming oc 3090 and EVGA ftw3 3080
I left majority of my G6x cards unmodded unless there's serious overheating issues with it
Each model is different so you'll have to measure or Google for your specific model
But both of mine uses 2mm, so I replaced them with 2mm thermalright odyssey pads
It depends on what you do
I own two gaming x trio 3090 and they both are pretty damn near 110c on mining workload
I also own a Galax HOF 3090, also near 110c but less severe than the MSI card by few c
Quite a few of my 3080 is also near 110c, except for Palit gamingpro lineup, those have been pretty chill with their VRAM around 90c instead of 100+ on my other cards
-sigh- feeling like I'm being too negative lately
i got a FE 3090.
wont lie got it for both a good price and it looks so fucking cool xD
but yea what should i use on it i get to 100c EASY when i do workloads.
cpu: 5950x
gpu: 3090 FE
Best,
Mu
Those are good temps. What is your ambient? I have a watercooled 3080 and am posting similar temps to yours. Albeit in a hot tropical climate with AC off.
