1 hour ago, Victor Bollen said:
Which PSU is better for this combination?
What combination? Full system specs please.
With a RM850x I don't think it's a PSU issue. Kernel Power is a general error for a not proper shutdown. It can be caused by dozens of issues.
2 hours ago, Victor Bollen said:
The CPU and GPU. I found already that I got a bugcheck code 124
Still haven't provided the system specs....
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
My PC specs are:
Motherboard: MSI MAG X570 Tomahawk WiFi
CPU: AMD Ryzen 7 5800 x
CPU Cooling: Cooler Master MasterLiquid ML240R RGB
RAM: G.Skill Trident Z Neo F4-3600C16D-32GTZNC
GPU: MSI Radeon RX 6900 XT Gaming Z TRIO 16G
PSU: Corsair RM850x (2018) (EU-model)
Just now, --SID-- said:
Motherboard BIOS fully up to date?
What powersettings in Ryzen Master?
What are the RAM setting in the motherboard BIOS?
Temperatures of CPU and GPU idle and load?
Motherboard has the last stabile version.
Powersettings in ryzen master are the default
RAM has XMP Profile for 3600MHz.
Temps in idle are both 40°C and load CPU 65°C and GPU 85°C
On 11/12/2021 at 10:42 PM, jonnyGURU said:
Using cable extensions on the PSU?
I use 2 pcei cables out of the PSU for the 3 8-pins connectors. I have a totally empty pcei cables in the box. Perhaps I have to use them all 3 for the gpu. I tried it already, but I have still the same problem. What can I do? A higher PSU?
