Monitor won't do 144hz
Solved by suedseefrucht,
16 minutes ago, Mel0nMan said:DVI connector
Wikipedia english:
QuoteFor practical purposes, this allows a maximum 16:10 screen resolution of 1920 × 1200 at 60 Hz.
To support higher-resolution display devices, the DVI specification contains a provision for dual link. Dual-link DVI doubles the number of TMDS pairs, effectively doubling the video bandwidth. As a result, higher resolutions up to 2560 × 1600 are supported at 60 Hz.
The german version of the Wikipedia page:
Quote2560 × 1600 60 Hz or 1920 × 1080 144 Hz
24+1 pins or 23+1 pins for Dual-Link DVI
So you need DVI-D dual link:
Your graphics card supports dual link:
