Hi friends,
I have a problem
I I am using a RTX 3080 with a 850w gold..
I bought a PCIe adapter and tried to connect also my GTX 1060 using it.
But the problem is that when I connect every thing with pc turned off the pc turns on just because I connected the GPU with the mother board..
and the USB 3.0 cable heats like crazy.
I had to buy another adapter as the USB cable burned.
Now I tried again and as soon the cable started to heat i dsconnected it.
How do i fix that? thank you a lot.
https://linustechtips.com/topic/1387012-pcie-adapter-usb-cable-heating/
Can you be a little more descriptive regarding what products (cables/adapters) you're trying to use here?
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
Yes sorry.
I am trying to use a RISER Card PCI-E 16X USB MINING / RENDERING 60cm VER.009s. in one of my graphics card slot.
I have now a RTX 3080 and I am trying to connect a gtx 1060 with the RISER CARD.    Z490 Taichi motherboard.
32gb ram
850w gold power supply
the usb cable is crazly heating.. and the computer even if I shut it down.. it turn on alone..
Hi friends,
I have a problem
How do i fix that?
32gb ram
==merged threads==
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
