Hey guys,
I own a set of Logitech z506 5.1 speakers which I enjoy using, however, I typically only use them as 2.1's because I find loose cabling suspending in mid air behind me to be an eyesore, and a hassle, all too often did the back speakers fall on the ground or get in my way. I was wondering what all of you guys do about this, how do you set up your back speakers, how far behind you are they?
Cheers
Chris
https://linustechtips.com/topic/138653-51-cabling-solution/
Cable extensions! Simple male to female plug will do the job.
NZXT Phantom windowed, Asus Z77 Sabertooth, Intel 2600K, Noctua NH-D14, EVGA 780 Classified, Crucial Ballistic Tactical, Crucial M4 128GB + Samsung 850 EVO, Corsair RM850, Creative X-Fi Fatal1ty Peripherals: Sennheiser HD598, FinalMouse Classic, SteelSeries Qck Heavy, Ducky Shine Zero (MX Brown), AOC G2460PF & Qnix QX2710
Build Log: Phantom - Antique Noctua
https://linustechtips.com/topic/138653-51-cabling-solution/#findComment-1848937
So you keep your rear speakers on the floor then? I don't think length is really the issue, though extensions may come in handy since I'm moving somewhere yet unknown in a few months.
Just in my last house I had one on a radiator that was never on, and the other on a shelf, at different heights, but I had little choice, my bed was in the way :P
https://linustechtips.com/topic/138653-51-cabling-solution/#findComment-1851753
I had gotten a Logitech Z5500 back before they were replaced by the z906. I was using a pair of speaker stands I'd gotten for the rear speakers, worked nicely but I'd stubbed my toes on the bottm of the speaker stands, and the loose wires were an eyesore and inconvenience. I trolled the local tech forums garage threads and saw that a set of Creative Surround Station for sale in very good condition.....needless to say, I snagged it w/o a moment's hesitation. The wires for the rear speakers run thru the inside of the 'arms', (you can see the wires in the middle of the 'arms where there is a joint) and exits again just before the speakers' location. I love it! Now, when I play games, the rear speakers are firing down just to my back on both sides for an awesome gaming, and movie viewing experience. Here's a recent picture of my setup....
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
https://linustechtips.com/topic/138653-51-cabling-solution/#findComment-1852481
That setup looks awesome!
But as it stands I need to keep the gear I've got and find a solution, and my desk doubles up as workspace so I need to be able to shift things pretty often.
Ughh, idk, maybe when I move house I'll look at space available and try and come up with something; thanks for your input though! :)
https://linustechtips.com/topic/138653-51-cabling-solution/#findComment-1869452
@Tacitus
Run wires under baseboards above the carpet. If no carpet, you can use thumbtacks to run the cables neatly along the base and up the corners. For me now, I keep all 5 speakers on my desk.
Air 540, MSI Z97 Gaming 7, 4770K, SLI EVGA 980Ti, 16GB Vengeance Pro 2133, HX1050, H105840 EVO 500, 850 Pro 512, WD Black 1TB, HyperX 3K 120, SMSNG u28e590d, K70 Blues, M65 RGB.          Son's PC: A10 7850k, MSI A88X gaming, MSI gaming R9 270X, Air 240, H55, 8GB Vengeance pro 2400, CX430, Asus VG278HE, K60 Reds, M65 RGB        Daughter's PC: i5-4430, MSI z87 gaming AC, GTX970 gaming 4G, pink air 240, fury 1866 8gb, CX600, SMSNG un55HU8550, CMstorm greens, Deathadder 2013
https://linustechtips.com/topic/138653-51-cabling-solution/#findComment-1869471
I have the same speakers. I just use a bunch of zipties and bunch the cables up and get them out of the way.
-Corsair 750D - MSI Mpower Z77 - 3570k @ 4.21 -Corsair H60- 8GB Corsair Vengeance 2133 Mhz- Corsair RM850 - MSI 780 Lightning -256GB SSD- 2 1TB HDDs - LG 23' Flatron - Razer Death Adder - Ducky Shine 3 Cherry MX Blue - Logitech z506 5.1-
Project - Bloody Lightning
https://linustechtips.com/topic/138653-51-cabling-solution/#findComment-1871786
