I had done it suceffuly in the past with other motherboards, by just using the screw driver method to bridge the pins (unplug the PC, find the clear cmos pins in the manual, use the screw driver to bridge them for a few seconds, i actually left it for a bunch of seconds).
But it refuses to work on a B550 aorus elite. Only can make it work by removing the battery, but the battery is behind the GPU and that makes it a pain. It does not have a clear cmos button.
What am i missing?
https://linustechtips.com/topic/1386292-clearing-cmos-problem/
You're not missing anything, you're just too lazy to remove a card..
Ryzen 7 5700X3D (CO -30) - AX370-Gaming 5 - 2x16GB @3600C18 - EVGA RTX 3070 8G XC3
[PBO2] CO -25/-25/-30/-30/-30/-30/-30/-30
[BIOS] Vsoc 1.1 / DRAM XMP
i5-6400 4.38GHz @1.36v (162.2 BCLK) - Z170M-Plus - 2x8GB @3244C16- Biostar RX 570 8G w/ MSI Armor cooler
[BIOS] BCLK: 162.2 (x27) / Vcore 1.35 / DRAM 3244 (XMP timings) / FCLK 1GHz (1622) / RebarUEFI patched
ROG G531GT : i7-9750H (uv) - GTX 1650 +700mem - 16+8GB @2666 - 1920x1080@145Hz (up to 172Hz) IPS panel
[Throttlestop] FIVR - Vcore -160 / Vcache -105 / iGPU+unslice -125 (IccMax 255)
i5-4690K + Z97-AR + Panram Blue DDR3 2800 2x4GB Lightsaber Blue
iMac 21.5" (late 2011) : i5-2400S - Samsung 4x4GB PC3-1333 - HD 6750M 512MB - cheap Winten SSD (MacOS High Sierra) - 1920x1080@60 LCD
Acer Z5610 "Theatre" Core 2 Quad Q9550 - 2x2GB PC3-1333 (Samsung) - 1920x1080@60Hz Touch LCD - great internal speakers
https://linustechtips.com/topic/1386292-clearing-cmos-problem/#findComment-15085863
Jokes aside, here's the manual: https://download.gigabyte.com/FileList/Manual/mb_manual_b550-aorus-elite-ax_e.pdf
The clear cmos jumper is right above the front panel connector
https://linustechtips.com/topic/1386292-clearing-cmos-problem/#findComment-15085867
If your trying to OC RAM for example do you think removing the GPU every time is a valid option? i was just asking why is it not working with the screw driver method
I have the manual and know were it is, it just doesn't work.
https://linustechtips.com/topic/1386292-clearing-cmos-problem/#findComment-15085868
Now I get it
I doesn't actually work when you jumper the pins, right?
Make sure your screwdriver isn't rusted or can conduct electricity
Leave it there for a moderate amount of time, say 10-15 seconds
https://linustechtips.com/topic/1386292-clearing-cmos-problem/#findComment-15085873
Just now, thekingofmonks said:
Now I get it
thanks for the help. I actually tried 2 different screw drivers and left it there for quiet a while, but i can't get the damn thing to work. Removing the battery works.
Do you think if i get one of those actual jumpers old motherboards used it will work, it wouldn't make any sense right as the screw driver should do the same. I'm desperate here (1st world problems i know)
https://linustechtips.com/topic/1386292-clearing-cmos-problem/#findComment-15085875
Safest / Best method would be to
Turn off the power supply from the on/off switch in the back or by unplugging the power cable.
Wait at least 5-10 seconds (so that 5v stand-by circuit will discharge and no longer supply power)
Either short those pins or unplug battery
if you unplug battery otherwise, the cmos may still be powered through the 5v stand-by from your power supply.
https://linustechtips.com/topic/1386292-clearing-cmos-problem/#findComment-15085907
