Will Halo Infinite 60fps be possible with good graphics on a GTX 1060 6gb?
Solved by Skiiwee29,
1 minute ago, AltF4_345 said:I do know that consoles are better optimized, being as you said it a static config, but it would be nice to play the game at medium with 60fps. PC requirements always confuses me, they usually not even state at what resolution and framerate the recommended requirements aim for. A 2070 is too much in my opinion if it aims for 1080p 60fps, which is the resolution that I play on.
Its hard to 100% definitely state how it will run until it launches, we can only surmise based on the minimum hardware requirements that your GPU, the 1060 6gb is right on the cusp of the low end, so I would wager you will get a decent experience at a mix of low and medium settings.
