So, I was trying to upgrade to Windows 11, everything works fine except for SecureBoot. When I turn on secureboot my main drive (Samsung 980 500GB) disappears from the boot drive section and appears again when I disable SecureBoot. Anybody knows fix or has the same problem? I need to have the SSD as a boot optiuon, cuz my OS is installed on it.
https://linustechtips.com/topic/1385888-asrock-b450-pro4-secureboot-problem/
1 minute ago, StDragon said:
The boot drive needs to be formatted in GPT (not MBR), and CSM mode needs to be disabled for SecureBoot to be enabled.
Okay, so where I can see if my SSD is formated in GPT or MBR? And if I have MBR the only option is to reinstall the Windows right?
SO, my drive is 100% MBR, how do I convert it into GPT when my OS is running on it?
