os not using ram
Go to solution Solved by BoomLiam,
32 bit Operating Systems only support (just shy of) 4GB of usable RAM. (about 3.8ish?)
Ok so i upgraded my system ran from 3 gb of ddr2 to 8 gb of ram and it doesn't appear  to be using it like i was rendering a video and it used like 1.5 gb of ram. and i looked in the task manager and its showing only 3 gbs of ram  is there a way to reset it ? Becasue it seams like its they os doesn't see it. Also its showing up in bios  i am running windows vista 32 bit
https://linustechtips.com/topic/138533-os-not-using-ram/
you need a 64BIT OS to take advantage of that RAM
just go get a 64bit version of the OS ur using and use the same key ur using for 32 bit it will work just fine
If your grave doesn't say "rest in peace" on it You are automatically drafted into the skeleton war.
https://linustechtips.com/topic/138533-os-not-using-ram/#findComment-1845363
Computer Specs (The Space Fridge):
CPU: Intel i5 3570k | Motherboard: MSI Z77A G45 | RAM: Kingston Hyper X Blu | SSD: OCZ Agility 3 (60GB) |
HDD: Seagate Barracuda (500GB) | GPU: MSI HD 7950 Fwin Frozr iii | PSU: Corsair CX600 | Case: NZXT Phantom 410 w/ NZXT Blue LED strip
https://linustechtips.com/topic/138533-os-not-using-ram/#findComment-1845366
ok so i need to buy a 64 bit os
also should i just remove 4 gigs till i do it ?
No need to remove them, just buy a 64bit os and upgrade.
Gaming Computer | Case: CM Storm Scout II | MB: Asus P8Z77-V LK | CPU: i5 2320@3,6ghz | GFX:  MSI GTX 770 Gaming | RAM: 8gb DDR3 @ 1333mhz | Storage: 1TB Seagate Barracuda | Monitor: 1x Asus VG248QE @ 144Hz , 1x Samsung SyncMaster SA300 @ 77hz OC'd
Other Device's | Phone: Samsung Galaxy S3 LTE@OmniROM | Tablet: Samsung Galaxy Tab 2 10.1@OmniROM | Laptop: Lenovo ThinkPad T61 Win 8.1
https://linustechtips.com/topic/138533-os-not-using-ram/#findComment-1845417
will the 750 ti play 4k video ?
https://linustechtips.com/topic/138533-os-not-using-ram/#findComment-1855254
