You could try a fan splitter, they sell them everywhere pretty cheaply. You could also try an adapter for your power supply, you wouldn't have any fan control for the fans hooked up directly to the PSU, but it'd get the job done if that's what you're looking for.
https://linustechtips.com/topic/1384815-pc-fan-splitters/#findComment-15074353
2 hours ago, maateo0511 said:
Hey, so I'm doing a case upgrade, and it would have 3 extra fans, and my motherboard only has 1 case fan header, would it be safe to put a fan splitter??
BTW, my board is a gigabyte b250m d2v
Should be fine with the fan splitter. I use them all the time
14700k
Thermalright frozen prism 360mm aio
B760 Aorus elite ax ddr5
32gb ddr5 G skill s5 6000mhz CL30
2tb wd black gen 4 nvme
2tb Solidigm P41 plus
2tb seagate hdd
Pny 5070ti
Fractal Ion 2+ 860watt platinum
Thermaltake View 380
AW2725DF 1440p 360hz oled
Aoc Q27G3XMN mini led
Ps5 Pro
Series X
https://linustechtips.com/topic/1384815-pc-fan-splitters/#findComment-15074469
It depends on how much power the fans draw and how much the fan header supports.
What fans are you using?
https://linustechtips.com/topic/1384815-pc-fan-splitters/#findComment-15074593
also take note there're 3 pin & 4 pin (pwm) splitters fan
for 4 pin pwm splitters, only 1 of the header will be 4 pin.
that's due to your mobo only need rpm reading from 1 fan to issue pwm control to all the fans on the same splitter
oh... try to use the same fan type on the splitter
Ryzen 5700x + EK Supremacy D-RGB | 2x8 GB DDR4 Klevv 3200 MT/s | MSI B550M Mortar | Palit 3070 GamingPro LHR + Bykski N-PT3070PRO-X | Corsair RM750 | Alphacool EPDM + QDC | Aquacomputer Quadro + HighFlow2 | EK D5 XTOP | Freezemod 360 30mm rad + Barrow Dabel-20b 360 20mm | Barrow & Freezemod fittings | Corsair 5000D Airflow
Audio: beyerdynamic DT 900 Pro X + iFi ZEN Air DAC + Razer Seiren Mini
https://linustechtips.com/topic/1384815-pc-fan-splitters/#findComment-15074715
