i got a work pc running a threadripper and such
and i want some cold storage for it. idea is i model allot and would want a hard drive to place the files in.
i dont mind if its abit slow cus the program opening it caches the info so i wont feel it if i open a file.
here is my question.
nas hard drives are slower but more reliable from what i know and even cheaper.
while stuff like the WD balck edition is faster but abit more expensive. but i donnu if they got the reliability pluses that nas gives.
so whats a good choice for my use case?
cpu: 5950x
mobo: asus tuf pro x570
gpu: 3090 FE
ram: 32gb G.SKILL Trident Z 3200 c14
psu: Antec HCP1300w Platinum (overkill i know...got it for a good price)
thats all needed right?...i didnt study for this exam....
https://linustechtips.com/topic/1384801-new-hard-drive-for-work-pc/
2 hours ago, Electronics Wizardy said:
How many tb?
Probably just get something like a ironwolf 12tb and get lots of storage.
THe nas drives have about the same performacne, and will work fine here.
8tb i found has a good price for the amount u get.
and so nas are a good choise? cus there cheaper then the "performance" drives i found
cpu: 5950x
gpu: 3090 FE
Yea the nas drives will be fine for you here, I'd save the money since you don't need performance.
