Buddy of mine asked my help with his PC. When I started disassembling the system I saw that his MB has 4 pin part of EATX power upside down (no idea how he managed to plug that in. His system does not power up. Can this short circuit the system and how bad is it in general? He says there was a strange noise coming from PSU when he tried to power it on.
https://linustechtips.com/topic/1384587-processor-power-plugged-in-upside-down/
That is REALLY bad. That would mean he provided +12v to ground plane of the motherboard. Best case scenario is motherboard and PSU is dead, worst, CPU, ram, motherboard, PSU is.
Hopefully the PSU catches a big short like this (and he didnt try turn it on too many times). The damage in theory shouldnt go beyond the connector's socket on the motherboard but the PSU could be dead.
Desktop benching:
Any half decent PSU might save a scenario like this but I would assume that would usually result in instant short circuit protection to kick in and not result in this.
1 minute ago, HoldMyBeerMF said:
So what is the extent of possible damage? Is it 'every component is fried' to '4 pin EATX socket is fried'?
Depends on how unlucky your friend is and how bad their component choices were.
To clarify, the noise apparently only appeared for what, an instant when he tried pressing power button on the chassis. So I don't know if the PSU handled the short circuit or not. And I def don't want to experiment with it
If we assume the PSU protection kicked in, will the components still be damaged?
Maybe, maybe not, only way to know is to plug things right and try.
F@H
GPD Win 2
If yo're lucky and the PSU's short circuit protection kicks in properly every time, there could be no damage. At worst it will melt the 4pin socket and maybe the plug, plus the PSU is dead.
I doubt the CPU and everything else except the motherboard will have any damage, because the way it is shorted you're not sending current through the whole motherboard like say, having both EPS power plugs in the wrong way.
5 minutes ago, Levent said:
not result in this.
My PSU makes a click every time I turn it on and apparently it's I think the NTC thermistor. I don't know what noise it is exactly but as long as it's not that of a spark, a puff or zap (i.e. exploding IC or capacitor) it shouldn't be a problem.
Desktop benching:
