After hundreds of people ( not really ) told me not to get it, I am going to get the Razer Kraken 7.1 or Pro. I would just like to know if there is any way to use the 7.1 on my phone? Do Female Usb to 3.5mm adapters work? I use my phone to listen to music a lot and I just would like to know if i could use the Kraken 7.1 on my phone? Is there any way that you can or is it just not possible? Thanks for your reply... Thanks.. Don't hate on Razer, i'm still getting them. :D
wow, thats a lot of bees!
https://linustechtips.com/topic/138285-razer-help/
Why do you need surround if you're just listening to music?
https://linustechtips.com/topic/138285-razer-help/#findComment-1837243
Razers not worth it. There are many options that are 100 times better. Senneheiser HD518 is only $80 on amazon right now and pair that with a zalman mic. Or spend a little bit more for a blue snowball/snowflake or modmic.
https://linustechtips.com/topic/138285-razer-help/#findComment-1837539
Thought I'd tell you this now, it's not surround, virtual surround is terrible (i know from experience :/)
Go for the normal analogue version with the 3.5mm jack/plug. It has native compatibility with phones/tablets and also comes with a 1x 4-pole 3.5mm plug -> 2x 2-pole 3.5mm plugs to go into your computer.
It essentially has one cable coming from it that integrate mic/audio into the same cable then has an extension that splits into audio and mic as two different 3.5mm plugs.
There will be no difference in sound quality between the 'surround' model and the analogue model, the only difference will be that the analogue is compatible with more devices, with literally no downside.
https://linustechtips.com/topic/138285-razer-help/#findComment-1844219
