Hello Linus Tech Tips! This weekend I'm planning on cleaning my PC/keyboard/monitor (EVERYTHING!) and I have a few questions.
1: I have compressed air, I know I should shoot the dust off, but then what? Wouldn't it just fall to the bottom of the case? If so what can I do to prevent this?
2: What's the best thing to clean the outside of a corsair 550D?
3: Tips for cleaning a mechanical keyboard?
4: What's the best thing to use to clean a monitor (to get off fingerpribts, etc)
5: Any safety procedures I should be aware of?
Thanks!
https://linustechtips.com/topic/138280-cleaning-help/
disassemble pc, clean each part, reassemble.
Cleaning 550D
Metal: Wipe with rubbing alcohol and cloth/paper towel
Plastic: Wipe with damp cloth(water only) wait till it's 100% dry. Using any cleaning fluids of rubbing alcohol can fade the plastic, I know as I've done this and the top panel of my case has faded slightly.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/138280-cleaning-help/#findComment-1837146
To clean peripherals I would recommend just using a microfiber cloth and wiping it down. Works fine for me. As for your keyboard you could possibly get a cotton swab and swab in between the keys, however it may not work with mechanical keyboards. I've never had experience with one myself.
https://linustechtips.com/topic/138280-cleaning-help/#findComment-1837149
Garden hose! :D. But seriously, you could get a vacuum and spray the various particles towards its direction. I'm probably not the best one to reply since I just hold things out the window and shake them a bit :D
Hmm not very good at this signature deallio so umm, specs :D
CPU: Intel Core i5 4570K Cooler: Cooler Master Hyper 212 EVO MBoard: Asus Z87-Deluxe RAM: Corsair Vengeance LP 8GBx1 Storage: Samsung 840 EVO 120GB; Western Digital WD Blue 1TB; Hitachi Clunk Clunk Whirl 1TB GPU: Asus GTX 780 Direct CU II Case: Antec 902 V3 PSU: Corsair RM 650 OS: Windows 8.1 Pro (with Media Centre)
https://linustechtips.com/topic/138280-cleaning-help/#findComment-1839821
Vacuum cleaner tip next to the area you're dusting off (at a fair distance, don't touch the components) in an open case, on the side (all cables out) in the middle of the room with open windows so you don't choke on the dust. You can take out the stuff that's easy to plug back in like extension cards.
For the keyboard, just google your keyboard top view, take all buttons out, clean the shi!t out of it and re-assmeble. My G15 went through few cleaning procedures like this and all I can say is be careful with long/large keys (I've snapped one of the plastic hinges on one of the shift keys, now it won't go down unless you press the 'working hinge').
To clean a monitor, turn it off, plugs out, let it sit for a few minutes, and clean it like a fragile piece of glass. Wet (not soaked) microfiber on one end, dry on the other. Wait for everything to evaporate + another few minutes, power back on. You can kill pixels otherwise.
Safety? And take time. Last thing you want is for a whole can of air or a vacuum cleaner tube to fall on some PCB like Thor's hammer. I managed to kill one of my RAM channels by not being careful.
https://linustechtips.com/topic/138280-cleaning-help/#findComment-1841925
Linus did a video on it  :D, just be sure to keep compressed air can upright, hold fans to prevent them from over-spinning when firing compressed air and use microfibre on the hard surfaces to wipe things off:
https://linustechtips.com/topic/138280-cleaning-help/#findComment-1845638
