trying to see if i get 48 ring ratio but at 47 ring its stable now with vccio 1.1v and used fornite lobby screen for testing the only reason i have that game lool but it still dips like from 440 to 170 for a split second alot less frequent with auto vccio voltage but is that normal for sometimes dips under 200 fps from 370-440
Main:
  • CPU
    10700k 5ghz All core 47 ring ratio 1.275v
  • Motherboard
    MSI Z590 A Pro
  • RAM
    4x8 viper steel samsung bdie: 4200-17-17-30
  • GPU
    Gigabyte RTX 3080 Gaming Oc
  • Case
    O11 air mini
  • Storage
    970 Evo Plus 500gb OS, Sn550 1tb, 860 evo 500gb, 2tb MX500
  • PSU
    RM750x (2018)
  • Display(s)
    Acer Nitro vg272up, Kogan 24 1080 120hz
  • Cooling
    arctic 280aio, EK M.2 NVMe Heatsink on 970 evo plus
    Second:
    Cpu: i5-8400
    Cooling: ID-Cooling Frostflow 120x
    Ram: 2x8gb 2666 c16 hyperx fury, tuned the absolute balls out of it but def not stehble.
    Mobo: Asus Prime H310M-K
    Gpu: Igpu
    Case: Coolermaster MB311L
https://linustechtips.com/topic/1382201-does-vccio-voltage-help-ring-ratio/
I secured 49x Ring with more VCCIO from my 48x values.
It helped me secure a better ringclock but its still likely ring and board dependant how much you'll need to increase... so many people have different opinions on how much to use so I won't go into mine...
But for me... yes.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
But for me... yes.
thanks i found that 47 ring is the max with 10700k 5ghz with vcore any higher and i can go to 5.1ghz all core so i think vccio or the cpu is limiting me but im happy the way it is rn, the vccio was on auto at 0.968 and i manually did 1.048 iand looks more stable in the menu but every like half a minute it dips under 200fps but i dont notice any hitching or dipping in gameplay in any game so ima start ocing the ram until i get a new kit 32gb and 3600mhz
Main:
  • CPU
  • Motherboard
    MSI Z590 A Pro
  • RAM
  • GPU
  • Case
    O11 air mini
  • Storage
  • PSU
    RM750x (2018)
  • Display(s)
  • Cooling
    Second:
    Cpu: i5-8400
    Gpu: Igpu
