Need help choosing my ram
The memory speed and timings are what affect performance, the brand and model of memory affect whether the memory will work on your motherboard (more unknown brands usually aren't on the QVL and can have issues with certain motherboards) and how good the warranty service will be if you happen to get something DOA. All three of those names are known for making pretty good memory, so given that they're found on your motherboard's QVL, they should work no problem. After making sure that they're present on the QVL, find which ever kit has the fastest frequency (up to 3600MHz, anything faster will have a hard time running on Ryzen), the tightest timings (the CL- number, lower is better), and what you think looks the best, in that order. Throw price in there as well as a sanity check to make sure you aren't paying double for CL17 compared to CL18 or something like that.
