display port cable
poole
Hey any of you guys know of any good DisplayPort 1.4 cable? I need one that is 2 meter long. My current one is giving me problems.
Any DisplayPort 1.4 cable should work just fine and do their job. Just read the customer reviews as always and you'll be good to go. I've purchased a combo pack of cables from Micro Center once for HDMI and worked great!!
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
Just buy one of the well reviewed ones off amazon. DP 1.4 cables are not hard or expensive to make so sellers have less reason to sell "fake" cables.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
2m is--as I understand it--on the top end of lengths DP cables can support.  That's one advantage of HDMI; it can support longer runs.  Don't know if that's a factor in what products you are finding, but it could factor in.
There are certified DP cables commonly available up to at least 5 metres, maybe more. There is no 2 metre limit.
Might just have been that particular Dell monitor then.  IDK?
