I Don’t Understand… help
Solved by GuiltySpark_,
14 minutes ago, Dr_badwolf said:... ... ... bro im trynna help, are you flexin at me?
You gave the OP unhelpful information as what you were trying to describe is lacking the details he'd need to perform that action.
14 minutes ago, ImBallistK said:GIGABYTE b450m DS3H WiFi in one of them.
F60 is the earliest BIOS revision that will support a 5600x. Since we can't boot up, we don't know what it has. Additionally, that board has no BIOS flashback capability so you'll need a compatible CPU (Ryzen 3000 or older) in order to test if that is the issue.
