Based on the hyper 212 black edition rgb product page, it uses a wired rgb controller, which means it has a box that the rgb wire connects to that has buttons on it to control the RGB.
Sorry I probably edited my post. Refresh plz. Build Specs Below.
System
  • CPU
    Ryzen 9 5900x
  • Motherboard
    ASUS ROG STRIX X570-F
  • RAM
    32 GB (2X8) Trident Z Neo 3600MHz CAS 16
  • GPU
    ASUS ROG STRIX RTX 3070
  • Case
    Corsair 4000D Airflow
  • Storage
    Sabrent 1 TB TLC PCI 4.0 NVMe M.2
  • PSU
    NZXT C850 Gold PSU
  • Display(s)
    BenQ MOBIUZ EX2710Q 27"
  • Cooling
    Corsair H100i RGB Pro XT 240mm
  • Operating System
    Windows 11
https://linustechtips.com/topic/1381256-pc-building-help/#findComment-15047705
No. There's a seperate cable for the LEDs in order to implement color control
Desktop benching:
https://linustechtips.com/topic/1381256-pc-building-help/#findComment-15047706
One plug from fan go into motherboard. Second plug from fan go to this box where RGB lights are controlled. So yes you will get rgb. Its possible the controller in the picture above will need power, but I doubt it will need an rgb header.
System
  • CPU
    Ryzen 9 5900x
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
    NZXT C850 Gold PSU
  • Display(s)
  • Cooling
  • Operating System
    Windows 11
https://linustechtips.com/topic/1381256-pc-building-help/#findComment-15047717
