Can anyone help me with F@H
Solved by Eigenvektor,
9 hours ago, linux fanboy said:how do you use the folding at home control ?
You need to quote or tag people, otherwise we get no notification of your reply.
For remote control, you need to enable remote access in the client's configuration (the F@H client acts as a server for web or control)
<config> ...other config... <allow v='192.168.1.0/24'/> <!-- Remote Command Server --> <password v='password comes here'/> </config>
Adjust "192.168.1.0/24" to match the IP range of your local network.
You should then be able to open remote control on any PC in your network and add the client by entering its IP and the password.
This is only possible after the client has been set up and started, of course. So you need to make the initial configuration on the Pi's terminal or UI.
