Does Bluetooth speaker has audio delay issue?
So I can't use wired speakers...so the only choice is Bluetooth speaker...does it have noticeable delay issue? If it's not noticeable then I don't mind... I'm think Logitech z337... anyone have used that speaker? I'm planning to use it for watching movie, gaming, music
Depends on the speaker and the game. Good bluetooth will have about 50 ms of delay, which is noticeable but not too awful unless you like rhythm games.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
Can a 4.1 Bluetooth speaker connect to 4.2 Bluetooth version on the TV?
Bluetooth has a noticeable latency period. Fastest BT audio protocol is APTX-LL (which is exclusive to qualcomm phones) and even that is 35ms as the best case scenario, otherwise it ranges from 100 to 300ms. Both are completely unacceptable for any sort of gaming.
Bluetooth speaker does has audio delay issues.
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
It really depends on the latency of transmission on the product. The name of the tranmission latency is escaping me right now, but if A/V Sync is important, there are late models of bluetooth that you can go with that have minimal de-sync
Quote for a reply.
React if I: Answered your question, helped, or made you laugh!
