PSU replacement
matangk
My parents have an old but perfectly functional desktop: h61 chipset, igpu.
The PSU is horrible. Huntkey cp-300, which some tech put there when the previous one died. It uses molex-to-SATA (and loose all you data) connectors, and hiccups on startup if we install an i5-3470, which forces us to use a pentium-G640 (half as strong). The PSU fan has become very noisy lately and I told them that the PSU need to be replaced ASAP.
In my country the cheapest brand options are
1. fsp hyper-k 500w
2. Antec atom b550 (orange label)
3. CM elite V3 p700
4. Seasonic core gx-500 on sale (maybe refurb?)
5. Data xpg pylon 650w
All are at $72-$78 range.
I tend towards the seasonic core, since i read some good reviews (available on intl. Websites) and I own one. Otherwise the XPG even though wattage is overkill.
Thoughts?
Thanks ahead!
That's probably the best one.
It's in Tier B of our PSU Tier List,
while The Antec Atom for example is in Tier D, so just for very very cheap systems.
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
Went with the XPG as the Seasonic was an open box return. Tier C but still with DC-DC and good reviews from Aris
