Hello everyone,
I'm trying to find a case for my new pc and I want to find a "small" one (smaller than my current which is the Phanteks enthoo evolv atx). I was thinking about buying the fractal meshfy compact 2, but my gpu is 336mm long and the case max gpu length is 340mm. Do you think my gpu is not going to be able to breath properly ? Will I be able to put a support bracket so my GPU doesn't sag ? And do you have any case suggestion ?
Thank you in advance
Mr.LovaLova
https://linustechtips.com/topic/1379269-case-maybe-not-long-enough-for-gpu/
