Monitor Characteristics
Get an IPS panel, at least 1920x1080. Size is your preference, most people like around 23-24". It's also worth noting whether the monitor is glossy or matte (anti-glare). Glossy usually has a bit more vibrant image but glare can cause issues depending on where you're set up. Some monitors don't list this spec directly, but if they don't then you can usually do a Google image search of the monitor model and look at the pictures to tell whether it has an anti-glare coating or not.
Refresh rate is 60Hz on standard monitors, but some "gaming" monitors use 120Hz panels which gets you a smoother image IF you have a graphics card good enough to get very high framerates. The current IPS panels on the market are also not capable of 120Hz, so if you went that route you would have to settle for a TN panel which gets you narrow viewing angles and more washed out colors.
Response time is basically a made-up number and can be ignored. Many people will tell you you need x milliseconds or below for a good experience, but this is a myth. As @helping said, it's a completely meaningless spec.
Dynamic contrast ratio is also a made-up number and can be ignored too.
