If you can increase your budget, an EVGA RTX 3060 gpu would be fine. However, I could only fit a GTX 1660 Ti in the list. You can decrease the price by going with the stock cooler, but for the Ryzen 5000 series I definitely would recommend going with an aftermarket cpu cooler instead.
https://uk.pcpartpicker.com/list/mRtB2V
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  (£241.80 @ Amazon UK)
CPU Cooler: Cooler Master Hyper 212 RGB Black Edition 57.3 CFM CPU Cooler  (£38.97 @ Clove Technology)
Motherboard: MSI B550-A PRO ATX AM4 Motherboard  (£98.99 @ AWD-IT)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (£63.60 @ Amazon UK)
Storage: Western Digital SN750 500 GB M.2-2280 NVME Solid State Drive  (£51.98 @ Amazon UK)
Video Card: MSI GeForce GTX 1660 Ti 6 GB VENTUS XS OC Video Card  (£374.99 @ AWD-IT)
Case: Corsair 4000D Airflow ATX Mid Tower Case  (£64.00 @ Computer Orbit)
Power Supply: Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (£79.98 @ Ebuyer)
£1014.31
EDIT: Going with an i5-10400F cpu would save you some money, and allow 1TB of M.2 NVME SSD storage. 🙂
https://uk.pcpartpicker.com/list/J6ffNP
CPU: Intel Core i5-10400F 2.9 GHz 6-Core Processor  (£146.86 @ Technextday)
Motherboard: MSI MAG B460 TOMAHAWK ATX LGA1200 Motherboard  (£99.98 @ Scan.co.uk)
Storage: Western Digital SN750 1 TB M.2-2280 NVME Solid State Drive  (£111.58 @ Amazon UK)
£979.96
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
https://linustechtips.com/topic/1376044-first-build/#findComment-15011262
PCPartPicker Part List
Motherboard: Asus TUF GAMING B460M-PLUS Micro ATX LGA1200 Motherboard  (£83.99 @ Scan.co.uk)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory  (£73.19 @ Amazon UK)
Storage: Kingston A2000 1 TB M.2-2280 NVME Solid State Drive  (£74.98 @ Amazon UK)
Video Card: Palit GeForce RTX 3060 12 GB StormX OC Video Card  (£465.46 @ Scan.co.uk)
Case: Fractal Design Focus G Mini MicroATX Mini Tower Case  (£40.47 @ Scan.co.uk)
Total: £964.93
Generated by PCPartPicker 2021-09-26 05:03 BST+0100
https://linustechtips.com/topic/1376044-first-build/#findComment-15011282
maybe a 6600xt instead? same price but better performance.
|:Insert something funny:|
https://linustechtips.com/topic/1376044-first-build/#findComment-15011289
there's no stock that's around that price.
https://linustechtips.com/topic/1376044-first-build/#findComment-15011290
I also recommend going for intel,
PCPartPicker Part List: https://uk.pcpartpicker.com/list/b8LB2V
CPU: Intel Core i5-10400F 2.9 GHz 6-Core Processor (£146.86)
Motherboard: Asus TUF GAMING B460-PLUS ATX LGA1200 Motherboard (£115.49)
(For the motherboard you can use a micro/mini ATX motherboard but I don’t recommend going for micro ATX and also I don’t recommend MSI motherboard because some people told me that MSI bios are awful)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory
(£63.99)
(I didn’t add a ram with RGB, if you can add one if you want and it will be another £10)
Storage: Western Digital SN750 500 GB M.2-2280 NVME Solid State Drive (£51.98)
(Actually I don’t know about WD SSDs and if they work alright but I add them because I saw that lot ok people add WD SSD for builds)
Storage: Western Digital Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive
 (£31.98) (If you want a HDD)
Video Card: MSI Radeon RX 6600 XT 8 GB GAMING X Video Card
(£429.99)
(64.00)
(You can change the case if you want but buy a good quality one with good cooling solution)
Power Supply: Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply (£79.98)
Total: £972.77 + £11.50 (Shipping)
Generated by PCPartPicker 2021-09-26 06:57 BST+0100
And also I don’t think you need a separate cooler for now because I also use a i5-10400F processor with stock cooler and I didn’t got any heating issues.
https://linustechtips.com/topic/1376044-first-build/#findComment-15011356
  • 2 weeks later...
(£63.99)
(£429.99)
(64.00)
The 10400F only supports PCIE 3.0, and B460 only supports 2666Mhz RAM.
Usually Gen4 isnt too uch of an issue, but the 6600 XT only uses an X8 link, which means that it runs at X8 PCIE 3.0, this can be a limiting factor. Especially in bandwidth heavy games like doom eternal.
https://linustechtips.com/topic/1376044-first-build/#findComment-15027363
