Can't control case fans in bios/software
Solved by IkeaGnome,
The fan speed controller to your front panel seems like it has to overwrite the BIOS settings. If you don't plug in "F" on the fan hub, do things start working better?
You could also try going to your BIOS and setting fan header D to DC mode instead of PWM. See if you can control it that way. The hub might not be reporting speeds back to the motherboard correctly.
Featured Topics
Rusty Proto ·
3
WildOne ·
Posted in New Builds and Planning1 -
solarbear ·
Posted in Troubleshooting0 -
4
2
2
tjrose91 ·
Posted in Servers, NAS, and Home Lab4 -
Ryoku ·
Posted in Power Supplies3
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
