Need help with Nvme installing on B550 Aorus Master!
Solved by Hairless Monkey Boy,
6 minutes ago, lamlam said:ut it only hit me now that if all 3 slot is occupied then the pcie lane of the graphic got slice in half running at 8x.
Exactly why I do not like that board. But, with 2 NVME drives installed, you are already running your GPU in 8x mode.
Quote* The PCIEX16 slot shares bandwidth with the M2B_CPU and M2C_CPU connectors. The PCIEX16 slot operates at up to x8 mode when a device is installed in the M2B_CPU or M2C_CPU connector.
That is an inclusive "or".
The two other PCIe slots run at PCIe 3.0 X4, so that's good news at least. It means you could run 1X 4.0 NVME and 2X 3.0 NVMEs at full speed without splitting the GPU lanes up if you use two PCIe to M.2 adapters in PCIEX4_1 and PCIEX4_2 slots.
