So for starters I've had this pc since February of 2020. About 2 or 3 months ago my graphics card went bad. The screens shut off and all the fans kicked up to 100. I reset the computer after waiting a bit and found out my graphics card was bad. This happened 3 times including yesterday. This time I think that my graphics cards shorted out because my system won't turn on with the graphics card plugged in to the psu.
I have no idea what would cause that to happen. Could the psu be pushing too much power to just the gpu? Or could it be some parts of my mobo? The gpu sit at less than 70° the entire time. Usually happens while I'm playing games. No other parts are seemingly bad so that pushes me away from the psu answer.
Components
Processor: Intel® Core™ i9-10850K Processor
Mobo: MSI Z490-A PRO
GPU: NVIDIA GeForce RTX 3060 Ti - 8GB GDDR6 - GIGABYTE GAMING OC
Ram: 8 GB x2 DDR4-3200 Memory Module - ADATA XPG SPECTRIX D41
PSU: Highpower 700W 80+ gold
https://linustechtips.com/topic/1374453-gpus-keep-going-bad/
Does your system work with a different graphics card? Got a friend's card to borrow ?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1374453-gpus-keep-going-bad/#findComment-14999239
9 minutes ago, RemiHemi said:
probably test the system with a low profile gpu, i swap out the psu whenever something gets killed, the manner of death also matters, i wouldn't plug any gpu of value into that psu anymore.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1374453-gpus-keep-going-bad/#findComment-14999242
1 minute ago, Pc6777 said:
possible, ive never heard of highpower before so i dont know if its a bad psu or not.
I looked it up and Apperantly they oem for some companies. I ordered a evga gt supernova 750 80+ gold. And I'll RMA the gpu again. I just hope that it is the answer
https://linustechtips.com/topic/1374453-gpus-keep-going-bad/#findComment-14999261
