And now it is (almost) complete.
Case: Meshify 2
PSU: Seasonic Focus GX-850
Motherboard: Gigabyte X570S Aorus Master
CPU: AMD Ryzen 5800X
RAM: Crucial Ballistix MAX BLM2K8G40C18U4B currently 2x8, plan to do 4x8 to populate all DIMM slots (I am doing it for the look)
GPU (currently): NVIDIA GeForce GTX 980 (Strix? got from a friend)
GPU (ordered): NVIDIA GeForce RTX 3080ti Aorus Extreme (not yet shipped 😞 )
Storage: Samsung 980PRO 1TB boot, 2x Samsung 980 1TB steam library
https://cdn.discordapp.com/attachments/765296446152507402/888830984462680094/image0.jpg
Current system. CPU: AMD Ryzen 7 5800X; MoBo: Gigabyte X570S Aorus Master; RAM: 2x Crucial Ballistix MAX 2x8 GB (BLM2K8G40C18U4B); GPU: RX 6900 XT Gigabyte Aorus Master; case: Fractal Design Meshify-2; Storage: Samsung 980PRO 1TB NVMe SSD + 2x Samsung 980 1TB NVMe SSD; PSU: Seasonic Focus GX-850; Cooling: Arctic Liquid Freezer II 360.
https://linustechtips.com/topic/1374231-my-first-full-pc-build/
And yes, I forgot to peel the sticker of the AIO.
https://cdn.discordapp.com/attachments/765296446152507402/888840945414582292/image0.jpg
https://linustechtips.com/topic/1374231-my-first-full-pc-build/#findComment-14997661
  • 2 weeks later...
8 hours ago, Elijah Kamski said:
A PC maker's worst nightmare XD
Glad you found out before any real damage was done though! 😄
I was a bit surprised by my thermals when running benchmarks, idle it was still sort of ok.
Then I decided to look through the trash for the build to see if the sticker was there (it wasn't) before removing it and re-mounting.
https://linustechtips.com/topic/1374231-my-first-full-pc-build/#findComment-15015308
Just for info, your fans in the front is pushing air out of the case. Don't know with your top fans, but the one in the back is pushing out to. If all is out then it will be bad..
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1374231-my-first-full-pc-build/#findComment-15015423
I am going to re-check it but I did move the fans on the AIO so they should be pulling air into the case via the rad. There is also a bottom intake fan.
https://linustechtips.com/topic/1374231-my-first-full-pc-build/#findComment-15016082
I rechecked too. Was just the picture quality that fooled me. They are correctly oriented. Didn't realized this before, but we have the same case. Kinda, I got the Define R6:
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1374231-my-first-full-pc-build/#findComment-15016270
Sadly taking photos is not my strong suit.
R7 would be closer I believe.
Nice but a bit weird GPU cooling solution.
https://linustechtips.com/topic/1374231-my-first-full-pc-build/#findComment-15016642
You can see the minor changes I did below, both the feeder fan below and the pre-wired PCI-E power I did for the expected 3080ti upgrade:
https://linustechtips.com/topic/1374231-my-first-full-pc-build/#findComment-15016668
Thats better, yes I run a naked 1080 ti.
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1374231-my-first-full-pc-build/#findComment-15017121
