4pin fan in an RGB header...
Solved by YoungBlade,
24 minutes ago, Toe_Inspector said:Fan said it was ran on 12v DC which is what got me confused in the first place, man that sucks
Looking into, it seems I misunderstood something. It's that the PWM control (pulse width modulation) is sent at 3.3v or 5v, not the whole fan's power. The motor itself is given 12v, but that's only on one of the pins. The pinout for RGB headers are not the same, so it's possible that it still sent too much voltage down the wrong cable.
