Steelseries apex pro help needed
bruhboi99
Hi guys, Im going to buy a steelseries apex pro and i want to keep rgb software on ym pc to a minimum so I was wondering if I could change the rgb to preprogrammed effects on the apex pro by pressing fn+(whatever keys they use to change rgb) keys? I was also wondering .f i could get this effect without using the software, Its called "Haze". Im giving an image below. Help me out if you can, Thanks in advance!
