Accidentally deleted part of C:\. Need help ASAP.
Solved by CommanderAlex,
6 minutes ago, 2plash6 said:
Then I typed "Del c:\". I was SURE that it would say access denied, but no. It prompted me, and I typed "y" for yes.
Have you tried in Command Prompt, sfc /scannow? (from the s to the w needs to be written).
EDIT: What |sfc /scannow| does is Windows will scan and check for any corruption on all protected system files and replace any corruption based on a cache.
