2 minutes ago, gaming guy said:
what does this mean?
Something is broken.  Either gpu, mobo, psu (typically)
For people to further assist you, you should post full specs of the pc however.
-Scott Manley, 2021
https://linustechtips.com/topic/1373566-help/#findComment-14992743
First of all, please try to make your thread title descriptive of the problem so that there is a better chance of someone who has relevant knowledge finding it. There are literally dozens of threads just titled "help" (or some variation thereof) each week.
Now then.
Did this PC ever function, or is this the first time you're trying to start it?
The white light on the motherboard is almost certainly a debug LED. Consult your motherboard manual to see what specific component it's indicating a problem with.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1373566-help/#findComment-14992746
Just now, MadGoatHaz said:
Need some background info here...
New build, existing build? Recent development? System specs? Recent upgrades? OC settings? ...
Give us some info, paint that picture for us.
its
2 month old build
no OC
r5 5600X
msi b550-a pro
g.skill trident 16gb 3600
gigabyte 3070
croshair rm 750w gold
https://linustechtips.com/topic/1373566-help/#findComment-14992756
Welcome to the Forums!!!
13 minutes ago, gaming guy said:
On the mother board there is also a white light. what does this mean?
What light is lighting up??? Take a picture and post it here if you are not sure.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/1373566-help/#findComment-14992762
White led generally means a CPU error.
Be sure the CPU PSU cables is seated correctly. (On both motherboard and PSU side, Unplug and reconnect).
Also disconnect all external devices, ssd and hard drives. If you can get it to boot, add one device back at a time. Process of elimination.
https://linustechtips.com/topic/1373566-help/#findComment-14992763
Just now, gaming guy said:
~Snipped Photo~
At least take a picture without the side glass on so we can see the lights closer?? Doesn't help with the glare.
https://linustechtips.com/topic/1373566-help/#findComment-14992768
20210915_175925.thumb.jpg.ba05465aadb53d74765d86935d120070.jpg20210915_175610.thumb.jpg.836ad6721dc48f61da0b576861d5a290.jpgthe pc booted up and the fans are spinning but the video out put is showing lines . does this mean my gpu is not working?
https://linustechtips.com/topic/1373566-help/#findComment-14992778
~Snipped Photos~
Looks like the white LED is for the VGA error of either not detected/failed. Have you tried to reseat the graphics card? If you don't POST still, then the graphics card is most likely dead, also given by the fact you have lines showing up on your screen (but check your video cable connections, as improperly seated cables can cause weird graphical issues).
https://linustechtips.com/topic/1373566-help/#findComment-14992786
looks like that is the problem. i tried reseating, reputing the cables and a different monitor but it does not work.
looks like my gpu is probably dead. I was playing Monster hunter world. when the computer crashed could the game be the problem or a faulty gpu? Edit (thanks for the help <3)
Edited by gaming guy
https://linustechtips.com/topic/1373566-help/#findComment-14992807
Alright. When the computer crashed, was this when it stopped booting up and is giving you the white LED?
Try turning the PSU switch off, hold the power button for 5 seconds, turn the PSU switch on and try turning on the PC.
https://linustechtips.com/topic/1373566-help/#findComment-14992811
when the computer first crashed it turned on again but then a few minutes after it crashed again then a third time
i tried the power switch thing and it didn't work it just turned on then showed the lines
i also made it into the BIOS is there anything i can do there?
https://linustechtips.com/topic/1373566-help/#findComment-14992820
Sounds like the graphics card is dying if it kept crashing. There's not much you can do in BIOS.
Are there any strange graphical issues going on in BIOS??? If so, the graphics card is defective.
https://linustechtips.com/topic/1373566-help/#findComment-14992823
there is no graphics errors in the BIOS
https://linustechtips.com/topic/1373566-help/#findComment-14992825
Still suspect there is a graphics card issue here. Can you possibly swap it out for another one or test your 3070 in a friend's PC?
https://linustechtips.com/topic/1373566-help/#findComment-14992877
