Corsair 650 RMX + 3070 ti =enough power?
Solved by FRD,
If your 3060 works, a 3070 Ti should be fine too. You can even run a 3080 on a 650W. Most importantly it must be a good quality PSU, which yours is.
I also use a Ryzen 5 2600, the power draw is not that crazy. Even if you had a 5600X it would draw a lot more power and heat, but it still would be fine.
650W is only not enough if you have a ton of fans, HDDs or other things that require extra power.
Featured Topics
jonrosalia ·
amir2927 ·
4
rb19 ·
Posted in Graphics Cards1 -
2
yepnew ·
Posted in New Builds and Planning1 -
TukangKopi ·
Posted in Networking2 -
2
